Monoblade Throttle body
Old Dec 7, 2004 | 01:06 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Ever since I have been on this board I had always heard that a bigger throttle body doesnt help unless you have heads/cam.... Well now that I have heads and cam I have been looking into it. I found a monoblade throttle body that AS&M makes for our cars that claims to outflow 58MM ones and was wondering if it is good or if anybody has used it. Open to any suggestions.
Chris
I found it at http://www.tbyrne.com/lt1catalog.html
Old Dec 7, 2004 | 02:34 PM
Z28SORR's Avatar
Re: Monoblade Throttle body
If I remember correctly the 58mm is equivalent to 900 cfm. This is more than most will ever need.
Find out what you Need then get the corresponding throttle body. Don't just buy what looks or sounds good.
Old Dec 7, 2004 | 04:01 PM
Turbo6's Avatar
I'm running the monoblade on my 383 solid roller car and it has worked out very well. I believe they rate it to flow ~1,300cfm which is much more than the stock MAF can flow anyway without significant pressure drop. If you aren't running a very aggressive setup with large heads, big cam, and increased displacement at 6500-7000rpm, the 58mm will be MORE than enough for your needs. To be honest, I probably wouldn't of seen much if any of a loss going with the 58mm on my setup but I got a good deal on it so got it instead.
Old Dec 7, 2004 | 04:04 PM
ah thats cool. Thanks guys. But do yall atleast agree that a 58mm would help me over stock?
Old Dec 7, 2004 | 04:18 PM
Evil Eric's Avatar
a 52 or 58 will definetly help you over stock with the mods you have.
Old Dec 7, 2004 | 04:28 PM
kmook's Avatar
Advanced Tech Moderator
True... but it's so purdy
Old Dec 7, 2004 | 09:06 PM
Haha yes but its also 569.99
Old Dec 7, 2004 | 09:31 PM
Turbo6's Avatar
If your car is making over 350rwhp, a larger than stock TB would probably help.
Old Dec 8, 2004 | 12:20 PM
hotrod18_69's Avatar
Indeed it does..
Old Dec 8, 2004 | 08:58 PM
XxXTransAmXxX's Avatar
Purdy yes, for the same price you can have Holley's 58mm Nitrous Plumbed TB though too.....ahhh yes decisions decisions for my 396....
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
