Those with the K-motion K-800 springs, come on in....
From what I have been reading, these springs don't require any machining... But I am confused on how you guys actually got these springs to go over the valve seals without interference.... Do you guys not use the valve seals at all and use O-rings instead with these springs, or is the inner spring big enough to where it just slips over the valve seal? If someone can clarify this for me, I would really appreciate it. Thanks.
Re: Those with the K-motion K-800 springs, come on in....
You have to remove the valve seal and remove the spring cup. Put in your shims or new cups for proper installed height. Reinstall the valve seal. Then the springs will go over them. You only need to remove the seals to get the old cups off, since the inner diameter of it wont clear the seal.
about 135 on the seat and 340 open just guessing. the 847 doesnt have very steep ramps there 62 degrees so it not a very agressive open and close. it not near as hard on the valve train as a EX grind.
The 847 calls for Closed 115 LBS and Open 336 LBS
The K-800 springs are
Installed Height 1.850
Seat Pressure At Installed Height (lbs) 165
Coil Bind Height 1.085
Open Height 1.150
Open Pressure (lbs) 495
So.... find the spring rate, and your needed installed height and go from there. I would actually recommend running a little more pressure than Crane reccomends
Open Height 1.150
Open Height 1.150
Open Height 1.150
well with those pressures you could never run stock lifters.
those are more than enough presures for that cam it only has 62 degree ramps the ex grind have a 52 degree ramps and the 987s are enough for the ex grinds.
Find the spring rate: (495-165) / (1.850-1.150) = (330)/(.700)=471 lb/in
Find the difference in installed height: 1.900-1.850 = .050 inches
Calculate load change for .050 travel : .050 in. * 471 lb/in = 23.5 lb, so seat load @ 1.900 = 165 - 23.5 or 141 lb.
You can do the same again for 1.95, which is pretty close to where mine were installed (on stock lifters)
Your turn: what do you get for 1.95 installed height?
Another friend of mine in Missouri had some on a 8 sec. vega and broke a couple! Again k-motion came up with some reason as to why they failed and wouldn't replace them. In my car the first one went about 6 months after I installed them with the cam. The second one went about 2 years after the instal.
423.9 open and 148.5 closed
but i was under the understanding that 400 i the limit for stock lifters.
You got messed up somewhere in your math...
Find the difference in installed height: 1.950-1.850 = .1 inches
Calculate load change for .10 travel : .10 in. * 471 lb/in = 47.1 lb, so seat load @ 1.950 = 165 - 47.1 or 117.9 lb closed.
Then for open you have (cam lift x spring rate) 471 x .595 (exhaust) = 280lbs + closed (117.9) = 398lbs open.
Not sure what the limit is on stock lifters, mine were just fine. I wouldnt guess there is an "exact" number that they fail at.
Louey
Pacific
Jul 21, 2015 10:06 PM
Catmaigne
Jul 14, 2015 05:17 PM
