Modifying the opti rotor?
Old Jan 14, 2008 | 10:45 AM
JasonK94Z's Avatar
I've read a few posts where people have modified the rotor in the optispark. They used rivets to hold the brass part down to the rotor? Can anyone explain this? Is it necessary on the new AC Delco units to do this now?
Old Jan 14, 2008 | 01:29 PM
LT4Camaro's Avatar
its a good idea to just take the rotor off and lock tite the 2 screws
Ryan
Old Jan 14, 2008 | 01:38 PM
JasonK94Z's Avatar
So people are opening up a brand new distributor to loc tiite the rotor screws too? No harm doing that? If not, i'll be doing it to my new one.
Old Jan 14, 2008 | 02:44 PM
wrd1972's Avatar
Yes this is great advice. The ones on my new GM opti wear not very tight which most likely would have backed out.
Old Jan 14, 2008 | 08:03 PM
JP95ZM6's Avatar
I just tore my opti apart to check the screws. One of them was loose, and the other was laying in the housing!! So, yes, locktite them.
I considered drilling and riveting the rotor, but instead I put a drop of thin CA adhesive (Cyanoacrylate instant adhesive for plastic/metal) onto each edge of the 'sandwich' of material where the heat stakes are. This gives a lot of surface area for the strength of the joint, between both metal parts and the plastic. IMO it will be stronger than even rivets. And easier. If you try this, a thin grade of CA is required so it can wick in to the gaps. Hobby shops carry it.
HarleyZ28
Oct 5, 2015 06:23 AM
Nellsw88
May 27, 2015 10:27 PM
Nellsw88
May 26, 2015 05:55 AM
May 1, 2015 01:14 PM
grgguy
17
Feb 23, 2015 07:57 PM
