mix n match.
Old May 6, 2005 | 03:35 AM
blackz97's Avatar
mix n match.
Ok another question,
Im getting ready to assemble the shortblock for my 355 buildup (stock crank no stroker). Im concerned with using the stock windage tray. I want to use ARP bolts because im not sure about the strength of the standard GM bolts (looking at 450 FWHP finished) but i know that in order to use the stock windage tray it might be neccessary to use a few of the GM studs just for those locations that the tray bolts too. Sounds sucky to mix n match but would it be okay? not recommended? Should i just ditch the stock windage tray and go with the canton setup?
On a short side note, is there any recommended spray cleaner and lube that I should use to do final prepping on parts before assembly? IE: cleaning bores stuff like that.
Steve
Old May 6, 2005 | 08:35 AM
BlackLT1_TX's Avatar
Re: mix n match.
I am using that exact setup spinning up to 6500...
Sep 17, 2015 11:53 AM
pimpen1024
Aug 19, 2015 08:36 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
warmeck
Mar 1, 2015 08:47 PM
