Missing and hesitation - 1/2 solved
Old Jun 21, 2011 | 07:11 PM
djdrew44's Avatar
I was getting a lot of missing and hesitation once the engine got hot. I scanned for codes and got a bad egr valve and left o2 sensor code history. I swapped out both parts and the problem has improved dramatically, but I still get a little miss and hesitation under very light acceleration. Another observation, that may or may not be related, is that the exhaust seems to get very hot. I actually feel heat coming through the console near the parking brake handle and out from under the car when standing next to it.
Any ideas?
Thanks.
Old Jun 21, 2011 | 11:41 PM
mrmint69's Avatar
Re: Missing and hesitation - 1/2 solved
Have you replaced plugs, wires or other stuff recently. More info on the car would be nice, like a little history and what not.
Old Jun 22, 2011 | 02:16 AM
djdrew44's Avatar
Sorry, just got the car a few months ago so don't know too much about it's history. I just replaced the opti a couple of moths ago. The wires and plugs appear to have been recently replaced. I should probably pull a plug to see it's condition. No ses light now btw. Do you think I should change the right side o2 sensor as well?
Thanks for your reply.
Btw: I've learned an incredible amount of information from this board. Thanks to all!
Old Jun 22, 2011 | 05:20 AM
Guest47904's Avatar
Guest
I don't see how plug wires would like new or old. The first thing I would do is identify any dead cylinders. Then start looking at the plug wire for that cylinder.
Old Jun 22, 2011 | 06:21 AM
Wild Willy's Avatar
If the miss is electrical, find a dark spot, at night, and pop the hood while the engine is running. Frequently high-tension electrical problems can be seen as an electrical light show, wires arcing. If it isn't spark, the next logical suspect would be a dirty or sticking injector. Easy to pull out and look at, or just go the lazy route and run some good injector cleaner through. Intermittent stuff can be a real bear to track down- tests okay when you test it, then acts up once in a while.
Old Jun 22, 2011 | 10:59 AM
mrmint69's Avatar
I replaced my 02 sensors after the car got 100K miles on it with AC Delco, just because and I was tired of always wondering if they were the problem I was tracking down. If you can scan it like with a lap top or other device you can see if the sensor is working properly.
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
techstar
Aug 6, 2015 11:20 AM
zajones
Jul 30, 2015 02:18 PM
Boss002
Jul 24, 2015 10:47 AM
