missing header bolt...
Old Jun 7, 2005 | 11:11 AM
narlydude's Avatar
Ok as i said in my other post i have a very long and difficult time putting in my headers. i prolly broke everything that was possible in a header install anyway i broke the second to last bolt on the driver side. i took the head totally out. i tried to get an easy out on it and take it out. no such luck....snapped the easy out in there also. lol ya i laugh at it now also. Anyway i took the head to a machine shop and they said it would cost alot of $$$ so i was like nevermind...since im getting new heads in a year. so i put my driver side head back on and just bolted up the header up...i was thinking that it would hold since it was the second last one and would most likely have support from the third one back....i just wanted to see what you guys thought? whats the worst thing that can happen? leak? blow a gasket?
tell me what you guys think
thanks
Old Jun 7, 2005 | 11:37 AM
sssalah's Avatar
Re: missing header bolt...
If your header flange is thick and you're lucky maybe it'll hold for sometime. most probably it will leak and once that happens the gasket will burn.
Old Jun 7, 2005 | 11:58 AM
valter's Avatar
I think you'll be fine for a year
Old Jun 7, 2005 | 11:49 PM
lt11997's Avatar
You are also going to need new head bolts if you haven't bought them yet since they are torque to yield bolts.
HarleyZ28
Oct 5, 2015 06:23 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
