missing and bad power loss issues
Old May 27, 2009 | 05:19 AM
hughett17's Avatar
its a 94 z28 a4 just replaced the opti with a new gm opti the car has 131xxx on the clock . the opti fixed one problem i had now theres another one . the car runs alright when i first start it in the morning while cold adn the warmer it gets the worse it gets . ive done the icm mod checked plug wires the o2s are new also. im running out of things to check here any one have any ideas i mean i can floor the car and its like bluhhh it just dont do anything i barely has the power to do the speed limit while its at running tempature any suggestions
Old May 27, 2009 | 05:21 AM
Guest47904's Avatar
Guest
Do you have any dead cylinders?
Old May 27, 2009 | 10:18 AM
brokegenetic's Avatar
You can double check plugs/wires and also check to see if the opti was installed correctly, and was the opti harness new? Maybe the old one has corrosion on it
Old May 27, 2009 | 11:27 AM
REDLT4's Avatar
I've seen clogged cats do this. Seems like it was all the time though, not just warmed up.
Old May 28, 2009 | 11:18 AM
steven92f's Avatar
would a bad opti cause it to miss? i have a 96 z28 with the lt1. the plugs and wires are all new. i put a new opti in it about 2 months ago. ran awesome for about an hour after opti was kinstalled and after that it car started to miss. check engine light is on so i hooked it to a scanner. cylinder 3 is about dead. more misfires than fires. and cylinder 6 has a few misfires but not many
armedtrigger
Feb 24, 2015 08:30 PM
DetroitZ28
Feb 13, 2015 07:33 AM
thenewkid
Nov 27, 2014 09:41 AM
XtremeLt1
Sep 13, 2002 08:50 PM
