Missfire / Blinking SES light
Old Sep 11, 2011 | 03:20 PM
6SpdLT1Z's Avatar
My SES light started to blink last night so I had it scanned this morning. The codes returned were for EGR (I need to have it tuned out as I removed it when installing Pacesetter LTs) and "Random Missfire."
It's my understanding that when the SES light blinks that's when the actual missfire occurs? I put the car up on jackstands earlier this afternoon and checked the wires (30k on opti and wires, 1 year/~3k mi on TR-55 plugs) for any burns. Then I noticed the #3 cylinder plug wire was lose on the plug, so I plugged it in and took the car out for a spin. Got halfway to the auto parts store and it missfired so I turned around and got on the highway and jumped on it. The car seems to run fine, and seems to missfire under moderate throttle at around 2-3k, or when downshifting.
Any tips on how to trouble shoot it further? I'm going to try to find someone who can help me datalog it as I don't have a cable. If it means anything the car seemed to be running a bit rich before the missfires started occuring so I suppose it's a possibility that the plugs are fouled?
Car:
1997 Camaro SS M6
154k miles
Pacesetter LTs, LT4KM, 3" ORY, 52mm TB, etc.
Headers were put on (had eldelbrock shortys before) Feb/March of 2010 at approx 151k which is when the plugs were changed out
Old Sep 11, 2011 | 04:31 PM
6SpdLT1Z's Avatar
Re: Missfire / Blinking SES light
Here's a clip of it in my garage with the door shut (I took this after as I was finished trying to see if the plug wires were arcing. I think the plug wires are fine. What's the next guess? Plugs? Coils? You can hear it backfiring as I let off the throttle.
[autostream]http://autostream.com/camaroz28/?page_type=firebirdplayerthumbnail&framepage=1703& transactionid=1315776677-99418585&posted_by=6SpdLT1Z_www.camaroz28.com&yout ube_video_id=Mujmrb25rEc[/autostream]
Old Sep 11, 2011 | 08:40 PM
You mention "coils".... do you have an aftermarket multiple coil system?
Old Sep 12, 2011 | 02:44 PM
6SpdLT1Z's Avatar
Sorry, typo. No coil packs / LTCC / etc.
I was just looking through my maintenance docs (which go back to ~130k mi) and the coil hasn't been replaced though it is possible that it was replaced at ~120k mi when the 2nd owner replaced the opti.
Old Sep 12, 2011 | 03:12 PM
Bersaglieri's Avatar
Unfortunately with miss-fires you might as well check everything. My car had one, it got worse and I dug deep and found more than one thing causing problems. Fuel pressure issue [pump/filter], cracked plug porcelain, tired lifters.
-Dustin-
Old Sep 12, 2011 | 03:26 PM
Guest47904's Avatar
Guest
A scanner should be able to tell you which plug is misfiring. I have a smart phone that does it for me with the blue tooth module plugged into the DLC.
Old Sep 13, 2011 | 11:37 AM
6SpdLT1Z's Avatar
Just the scanner at the local auto parts store? Looks like they test coils also so I'm probably going to run up there and have my coil tested and the code rescanned.
Old Sep 13, 2011 | 12:45 PM
6SpdLT1Z's Avatar
Question: I blocked off the EGR tube from the PS manifold/header to the intake back when the PS shorty header was installed in 2007. I still haven't had the EGR tuned out of the PCM , and the EGR valve is still on the back of the intake manifold. Could this be causing it? A tune and removing the EGR valve was on my list of things to do this winter / next spring, just wondering if this could be causing the issue, and if so... why is this issue finally presenting itself now?
Old Sep 13, 2011 | 02:20 PM
moparman's Avatar
Don't know if the EGR is causing the problem, but if the SES is flashing, that is the sign of a misfire. Take it to Autozone or somewhere else that pulls the codes for free. Remember the code(s) and post them here.
Old Sep 13, 2011 | 07:20 PM
6SpdLT1Z's Avatar
Apparently autozone can't test our coil, but I scanned the car again with a code reader at O'Reilly Auto.
  • P0300 - Random/Multiple Cylinder Misfire Detected
  • P0400 - Exhaust Gas Recirculation Flow Malfunction
Obviously I previously had the P0400 code error and was aware of it due to my blocking off the EGR pipe from the PS manifold/header to the intake manifold.
Car seems to misfire between 1600-2500rpms under moderate throttle/load. Runs fine at upper rpms and idles fine.
Old Sep 13, 2011 | 08:41 PM
6SpdLT1Z's Avatar
Looks like I've got a burnt #5 plug wire.
Any suggestion on a new set of wires? These are MSD SuperConductors
Old Sep 14, 2011 | 12:57 AM
I'd say MSD's if they weren't so damn expensive. On my beater car I run Oreilys cheap set. They are actually very nice for the money and made in the USA.
-Dustin-
Old Oct 5, 2011 | 01:22 PM
6SpdLT1Z's Avatar
Got a set of MSD's out for delivery today so hopefully she'll be running like new later tonight.
Dzmaro
May 7, 2015 09:33 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
