Missfire After Cam Swap!!!!!
Old Apr 15, 2003 | 01:09 PM
SMOKD U's Avatar
Angry Missfire After Cam Swap!!!!!
I put in my cam heads the whole deal. ...... misfires like all HECK! I work at a Chevrolet Dealership and its in service right now they are trying to figure out what is wrong....
Just replaced OPTI ----> No better same thing
Replaced plug wires and plugs ----> Same thing
Replaced Coil ----> Same darn thing
its getting a 300 code on cylinders 2 and 7
Someone please help!!!!!
1997 z-28 6 speed, AFR LT4 heads, Intake manifold, CC306
Old Apr 15, 2003 | 03:15 PM
tanker's Avatar
reply
I just did my heads/cam/rockers/optispark, and when I first started the car, it misfired too. At first I thought I did a mistake with timing or opti spark, but all that was wrong was too tight rocker arms. If you put a bigger cam, probably you will need to loosen up your rockers even if you didn't change them. If you could get your spark plugs out, then you could turn the engine by the crankshaft hub and see how easy the engine turns.
Old Apr 16, 2003 | 05:17 AM
HungryT/A's Avatar
Re: Missfire After Cam Swap!!!!!
You have an OBD2 car! It has got a crank position sensor, that is supposed to detect cylinder misfire by watching the crank rotation speed and firing order.
Now you've put in a CC306, that must have a lope like a ****, and your CP sensor thinks it is a misfire! I don't know what can you do about it.... maybe change to OBD1..
Old Apr 16, 2003 | 08:08 AM
Black97Z's Avatar
Re: Re: Missfire After Cam Swap!!!!!
or get some tuning for his OBD2... he didnt mention tuning, but tuning is DEFFINATELY neccissary with the 306 and heads.
Old Apr 16, 2003 | 09:11 AM
GREGG 97Z's Avatar
The CPS doesn't have an effect on how the car runs, it just "detects" misfires. I still have OBDII and had my CPS sensor programmed out when I switched to a cloyes chain. I drove it for a while after removing the CPS reluctor ring and with the sensor still active and I just got an SES for it, it didn't effect the engine performance though. I would think he needs some programming for the new heads/cam though.
Klypto
Mar 23, 2016 09:05 AM
jj_burchiel
Mar 5, 2015 07:05 AM
chuyz28
Feb 19, 2015 12:50 AM
chuyz28
Jan 15, 2015 04:14 PM
chuyz28
Nov 25, 2014 11:14 PM
