Missfire
Old Aug 21, 2003 | 01:23 AM
Mellowdork's Avatar
Missfire
Hey guys. I got this p0300 code that everyone is always talking about, on my 96z. Heres what ive done. New wires, new plugs, new egr valve. I normaly put a new fuel filter in about every year, it is time again. Ive owned the car for 2 years and ive never did a injector cleaning. You guys think its a fuel problem? or an opti problem? And its kinda odd cause i put all them new parts in about a month ago. It ran fine up to a couple days ago. I checked all the wires plugs and vacume lines. Now im stuck. What else should i look at?
freddy
Old Aug 21, 2003 | 08:50 AM
EviLBoX's Avatar
Did you check the coil wire? Since the P0300 code is the random misfire code, it's probably something that's effecting all the cylinders.
Old Aug 21, 2003 | 04:44 PM
Mellowdork's Avatar
Thanks for the reply. I just did that rightnow. It was bad indeed. It had twice as much resistance as the new wire that i put in. I dont know if this fixed it or not. I turned the car on and the light is still on. Though the moter idled much smoother. Im going to take it for a test drive to see if the light turns off.
freddy
Old Aug 21, 2003 | 10:57 PM
Mellowdork's Avatar
Yeap that did the trick. No more light. She purrs like a kitten. thanks dude.
99 z28 Haas
Apr 23, 2004 07:25 PM
street demon2k3
Mar 27, 2004 08:27 AM
eds96ragtop
Mar 5, 2004 04:43 PM
MattysTA
Feb 7, 2004 12:20 PM
ledfootz28
Nov 8, 2003 07:28 PM
