misses and stumbles
Old Apr 18, 2005 | 11:43 AM
nmemry3's Avatar
misses and stumbles
hello new member here i have a 94 Z-28 lt-1 auto runs real rough when you start it misses real bad new coil plugs wires fuel pressue is perfect exhaust pipes are real black car runs rough like i said but if you stomp on it it goes strong but misses and back fires a little ive been tracking this problem for a while please help pleaaaaaassee!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 18, 2005 | 11:51 AM
biltLT1's Avatar
Re: misses and stumbles
Optispark
Old Apr 18, 2005 | 02:01 PM
nmemry3's Avatar
i was thinking that to thx
Old Apr 18, 2005 | 04:08 PM
blaze309's Avatar
Seriously i wouldnt got replacing opti-spark right away. I SEE WAY TO MANY people blaming everything on the opti. I have a problem similiar to your's, i'm going to explain my problem to you so you can see if your's seems simliar. When i start up my car no matter if it is warm or cold at idle my car will sit there and shake and i can notice the rpm's dropping a tad. When i'm driving and trying to maintain a speed it'll start stumbling really bad and the car will start shaking. This is defintly noticable when you try to go up a hill, and even more so when you go up a hill in 5th or 6th. When i go wot it seems to clear up more-so than just cruising but the car just doesnt pull like it use to. Well a few days ago i tried some fuel injector cleaner, and a day or two after that my car got noticably better, i mean a whole lot it was actaully not annoying to drive anymore. The problem still isnt completly gone but i'm going to run some seafoam through my car. And if i let my car sit for a day or so without running the next time i start it, it'll be missing really bad but with that injector cleaner it seems to clear up after about 10 minutes. I would try some fuel injector cleaner first since it's cheap, and also a fuel filter. Also at night you can start your car and look under the hood and see if you see any wires arcing.
Old Apr 18, 2005 | 09:07 PM
nmemry3's Avatar
i tried fuel injector cleaner did not help the new wires seem to make it a bit better but still runs real bad
Old Apr 20, 2005 | 01:37 PM
nmemry3's Avatar
thanks for the help it was the optispark it had a big hole burnt thru the back and the rotor was loose put some seafoam in it its running real strong thanks again
Old Apr 21, 2005 | 04:27 PM
keng's Avatar
HOw hard was it to pull the opti
Old Apr 21, 2005 | 05:12 PM
BLinindoll's Avatar
Gotta pull the fans, coil, air pump, water pump, and crankshaft balancer pully. Fun stuff.
93 RedBird
Nov 15, 2015 08:24 AM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Ks0209
Oct 1, 2015 07:32 AM
tommalcolm
Sep 11, 2015 03:39 PM
