Miss at low RPM, high load...help!
Old Feb 25, 2005 | 03:33 PM
heliskiier1's Avatar
Question Miss at low RPM, high load...help!
Hey guys,
I got a miss when engine under load at under 2000 RPM (i.e. 6th on highway at 55 and I jump on the gas I get a miss until RPM's come up, also happens anywhere else where I'm under 2000 and load up the motor). Once RPM's are up, no problems.
Car fires with 2 turns every time. Decent Idle. No smoke or other problems. Runs real good except the miss.
Anyone got any ideas? I'm stumped?
On a positive note, my LS1 brakes are in and they ROCK!!!!
mudkat
Old Feb 25, 2005 | 03:35 PM
americanmusscle's Avatar
Re: Miss at low RPM, high load...help!
How many miles on the car?
Old Feb 25, 2005 | 03:40 PM
Chevycobb's Avatar
got the exact same problem. Has it shown any codes yet? Mine showed a bad O2 sensor, so i changed it and it helped somewhat. I checked all my plugs and wires and the looked ok, my new opti came today, so i hope that's what it is.
Old Feb 25, 2005 | 03:46 PM
Might also want to check your fuel pressure. When my fuel pump was going out the car would miss around 55 -60. Replaced the pump and it took the problem away.
Old Feb 25, 2005 | 04:02 PM
gonna check codes next week...man I hope it's not the Opti...it's definitely not clutch slippage and it doesn't just happen at 55-60, but always at 1500 R's when I load up the motor...usually in a higher gear like 3,4,5, 6 at lower speed.
Old Feb 25, 2005 | 04:12 PM
Chevycobb's Avatar
I know exaclty what you mean. It feels real rough up until about 2500 then it smooths out and feels fine. Ive been telling people that I HAVE to go fast or it won't run well
Old Feb 25, 2005 | 05:32 PM
med_reject's Avatar
if i was allowed only 1 guess, i'd say spark plug wire(s)
Old Feb 25, 2005 | 05:49 PM
raroz28's Avatar
Hey guys,
You should NOT be in 6th gear going 55. You should be in fifth. If you have it in sixth gear and are going 50-55 MPH, the car will hesitate until it gets into a better RPM range for that speed. Downshift to fifth, get up to your desired speed, and chill it in sixth.
I never use sixth unless I'm going at least 65-70.
Old Feb 25, 2005 | 06:02 PM
Thanks for the driving lesson...sure appreciate it! I'll try not to let it down to 55 in 6th...geez, was just describin the problem and it is a miss for sure.
Old Feb 25, 2005 | 06:03 PM
wish it was plug wires...they're new...only 3x miles on em...hey, it still cooks when it's on the pipe!
Old Mar 23, 2005 | 08:33 AM
wlz28's Avatar
Did you ever find out what the problem was??? I've got the same thing going on
Old Mar 23, 2005 | 09:32 PM
Chevycobb's Avatar
well, I know it's something in the tranny. I haven't gone to the drivetrain forum but i will now. I know it's the tranny because if i'm drivin gin 5th and it feels rough, i'll just shift to 6th and back to 5th, but won't actually hit the gas while in 6th, and when I go back to 5th, feels fine. I'm thinking just a tweaked shift fork....
Old Mar 26, 2005 | 12:56 PM
golanr's Avatar
I had the same problem,
First time I tried to fix it, I changed the plugs and wires including the wire from the coil to the Opti. Problem fixed.
After six months it started again, this time I bought a scantool and I got strange results on my IAT sensor, it was showing 155F when the outside air was 40, so I pulled it out and tested it, it came out just fine, I checked the voltage on the connector and it was fine as well (5V)
So I decided to just disconnect the IAT sensor, guess what.....car pulls great, no more miss/hesitation/stutter.
I put a new one in and teh car pulls great
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
TrouserSnake
Aug 7, 2002 12:43 PM
