miss at high RPms? help!!!!
Old Dec 21, 2003 | 11:49 PM
cridom's Avatar
Angry miss at high RPms? help!!!!
for about 2 month now my car misses always at about 5.5 or 5.8 rpms. i dont know what it is it only has 50k miles and ive replace intake elbow ,welded catback and cai. i dunno what is causing this.
my plugs are the original ones the have never been changed and my dad work with splitfire so i got plugs and cables for her but i dunno if this will help ... please help me.
(i also got a tach w/shiftlight from them are they good?)
Old Dec 22, 2003 | 12:15 AM
PonyStalkerZ28's Avatar
Hey man, I had the same problem with my car doing that under full throttle at around 5,500rpms. I took my car to several places trying to figure it out and no one could tell me for sure what it was. Well, I talked to my friend Patrick(a.k.a. pattymelt) and he told me he was more than sure it was the optispark. So, I replaced the optispark system and havent had that problem since. It can get pretty expensive, so I would check with other people and see what they think it might be first, but it sounds like thats probably your problem. If you have any other questions or need some other help just PM me, or try me on AIM(PonyStalkerZ28).
Old Dec 22, 2003 | 12:16 AM
96ta(nick)'s Avatar
I have the same problem but my opti is new....
Old Dec 22, 2003 | 12:27 AM
Opti can be known to go out whenever it wants to, my friend had to replace his on his vette four times in two years. How new is it? It could be something else though, so check around and see what other people say.
Old Dec 22, 2003 | 12:28 AM
cridom's Avatar
well lemme tell u a story about my car.
when i bought her i drove her 1hr and 45min to my house and it was a paradize!!! so when i got home the next day she took a bath and i prayed some engine bright and soaked her after. well 20 min later my car run like crap and it would stall. i didnt touch her for 4 days and i guess it dried but 2 month after the missing problem came back.
i guess it can be the opti.
is it hard to replace or ust time consumming?
Old Dec 22, 2003 | 12:43 AM
It probably is it then, thats the problem with washing the engines of F-body's. If you get the optispark wet, your pretty much screwed. Mine wasnt that hard to replace because my motor and everything else were already out of the car when I did it. It can be a pain when the motor is in it though. The opti is behind the fans, the water pump and all that other junk. So it is pretty much just time consuming and a pain because you have to remove all that stuff.
Old Dec 22, 2003 | 10:11 AM
1loudz's Avatar
i had a miss in the exact same place about a year ago, and it turned out my coil wire was bad. often a high rpm only miss ir related to the coil or coil wire. check those b4 you do the opti.
-Ryan
lt1matt
Mar 21, 2015 07:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
1996LT1Z28
Mar 8, 2015 08:16 PM
DetroitZ28
Feb 13, 2015 07:33 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
