Misfire??
Old Apr 9, 2011 | 09:20 PM
sconley1028's Avatar
Misfire??
Hello, And first off i want to say thanks for anyone who helps me with this problem I'm experiencing.
I have a 97 z28. I recently took the heads off and the intake off to reseal everything and replace anything that was worn or broken. I ended up putting the old opti back on and a new water pump (which ended up being a defective pump) when i started the car up it ran real bad and then died. and of course the water pump was leaking on EVERYTHING. I ended up taking all the front pieces back off and replacing with a new opti another new water pump and while i was at it i changed the coil and the icm.
Now the car cranks..., but its off. its not running smooth and it feels like its missing.
When i hook a code reader up to it it says random misfire.
Could this possibly be because i tightened up the valves to tight when i put the heads back on??
I heard that if u over tighten that it would make it run bad if it would run at all.
Any suggestions would be soooo appreciated.
I feel at my whits end
Old Apr 10, 2011 | 09:12 AM
Re: Misfire??
"over tighten" what?
Are you sure you have the plug wires on the Opti in the correct order?
Old Apr 10, 2011 | 08:31 PM
ACE1252's Avatar
Re: Misfire??
I think he's asking if he got the rockers mis-adjusted would it misfire?
Old Apr 10, 2011 | 10:47 PM
Talking Re: Misfire??
FIX'D IT!!!!!! It was the valves being over tightened. I started over and set the vales at zero lash with a half extra turn on each one. It purrs like a kitten now!
I went on shoebox and read about setting the valve lash and that is where i read that if they were overtightened the car would run like crap if it would run at all.
Old Apr 10, 2011 | 11:00 PM
ACE1252's Avatar
Re: Misfire??
Glad you got it fixed!
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
Schul365
Aug 22, 2015 10:00 AM
Girrrrl
Aug 20, 2015 09:26 AM
zajones
Jul 30, 2015 02:18 PM
