Misefire at the Redline
Old May 5, 2005 | 07:26 AM
foursquare's Avatar
My car misfires at the redline, consistently at the same spot. What could it be? The plugs and wires are both new. Could it be that i need a new coil? Or is it time to replace the opti? I'm thinking its the opti, but if some of you could give me some of your thoughts that would be great.
Old May 5, 2005 | 07:36 AM
96ZRDR's Avatar
Re: Misefire at the Redline
Ummmmm. You might be feeling the rev limiter, unless you disabled it? Stop hitting it.
Old May 5, 2005 | 08:59 AM
Rashiki's Avatar
Yea, i'm thinking rev limiter... somewhere around 5800 - 6000 rpms?
Old May 5, 2005 | 10:21 AM
95z28athome's Avatar
You have an A4, unless your manually shifting it your not hittin the limiter without running the gear out first. I had a problem with it doing that so I just went in and blew everything off real good with the air compressor all around the electronics and the opti, moisture on an opti can be decieving, if problem pursists-probably time for a new opti. Although, what kinda plugs you running?
Old May 5, 2005 | 10:24 AM
madwolf's Avatar
Another possibility is that your transmission is slipping or low on fluid and it takes too long to shift, thus hitting the rev limiter.
Old May 5, 2005 | 06:56 PM
foursquare's Avatar
I'm pretty sure the guy i bought the car from replaced them with the factorty AC Delco ones. When my headers go on in a couple weeks i was going to get them to put in NGK TR55's. Thanks for the info so far, anyone else have anything to add?
Flint78
Jun 21, 2015 01:28 PM
warmeck
May 7, 2015 02:10 PM
Nickster 7
May 1, 2015 09:04 PM
bossco
Nov 29, 2014 10:18 AM
The Captain
V6 Tech
Mar 28, 2003 10:32 AM
