Minimum rpms?
Old Mar 27, 2005 | 12:56 PM
fearnside5's Avatar
Minimum rpms?
What should this setting be for a 95 auto. ?
Old Mar 27, 2005 | 11:44 PM
Re: Minimum rpms?
Do you mean "what is the stock programming for the idle speed"? If so, with the engine fully warmed up, the A4 should idle at 550rpm in gear, and 650rpm in neutral. Remember, the stock tach will read 100-200rpm high.
Old Mar 28, 2005 | 06:08 PM
fearnside5's Avatar
Re: Minimum rpms?
programming with hypertech programmer until i can afford a decent tune. The option for minimum rpm is what I'm looking for. set it to 550 or 650?
Old Mar 29, 2005 | 12:14 AM
Re: Minimum rpms?
I didn't know the HPP could alter the idle speed. Learn something new every day. Why do you feel you have to change the stock programming? Is there some problem with the idle? If not, leave it alone.
Old Mar 29, 2005 | 12:28 AM
pHEnomIC's Avatar
Re: Minimum rpms?
I wouldn't mess with the idle. Your car may suddenly die at stops and you may not be able to get it running again once warmed up.
Btw. anyone know if you can make a car sound lopey by lowering the idle (just curious, wouldnt do it)?
Old Mar 29, 2005 | 12:46 AM
redcamaroz28's Avatar
Re: Minimum rpms?
With a larger cam you will be able to hear the lope more with a lower idle. You won't even be able to hear the lope on the stock cam with a low idle unless you can somehow manage to keep it idling at 100 rpms.
Old Mar 29, 2005 | 05:39 AM
fearnside5's Avatar
Re: Minimum rpms?
HPP doesn't have an option to set idle just minimum rpms. Car is set to 800 min. rpms now and that appears to be the idle. Sorry if I'm confused.
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
