Mini starter too close to Y-Pipe?
Old Apr 11, 2006 | 03:42 PM
TUFF LT1's Avatar
I recently installed a new summit mini starter. To make a long story short, it barely fit with my AS&M headers, Now that it is installed, it is only about 1/3 of an inch away from my Y-Pipe. Is that too close and will just cause it to go bad or will it be OK? I checked into that header wrap but it will just touch the headers and burn through and probably cause more heat transfer. The directions on it said not to place it within 2 in. of exhaust or it would be damaged. Any suggestions? Maybe wrap the y-pipe where it is near the starter? I didn't think that was good for the exhaust coating though? Thanks!
Old Apr 12, 2006 | 05:19 AM
Guest47904's Avatar
Guest
Re: Mini starter too close to Y-Pipe?
What choice do you have? do you think that's what killed your other starter?
Wrap both the headers and the starter or replace the headers. But only wrap the header in the area of the starter.
nuff said.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
Toxintwins
Sep 11, 2015 11:13 AM
