Mini Starter
Old Apr 25, 2005 | 01:03 PM
PWR SHFT's Avatar
Mini Starter
I have a Summit Racing mini starter sitting on a shelf. Does anyone know if it would work on an LT1?
Here is the link to the starter:
http://store.summitracing.com/defaul...2&autoview=sku
Old Apr 25, 2005 | 01:14 PM
Evil Eric's Avatar
Re: Mini Starter
depends on if the teeth on the starter match up with whatever flywheel you have. i diddnt see it on the summit page, but id say thats the only drawback.
Old Apr 25, 2005 | 01:34 PM
PWR SHFT's Avatar
Re: Mini Starter
According to Summit, it will fit all SBC and BBC with an inline bolt patern and with 153/168-tooth flywheel.
What about the electrical connections? Do they match up? Or do we have something unique?
Old Apr 25, 2005 | 01:40 PM
PWR SHFT's Avatar
Re: Mini Starter
Do LT1's utilize an inline bolt pattern or do they use and offset pattern? Or, are they drilled for both?
Old Apr 25, 2005 | 01:58 PM
nathan96's Avatar
Re: Mini Starter
It should work okay, can it be adjusted to clear the block or exhaust if they are in the way? The bolt pattern will be fine, and it should just be a matter of taking the old one off and putting the new one in. Don't forget to unhook the battery!
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
Jul 17, 2015 02:47 PM
