Milodon windage tray studs installed....question
Old Apr 1, 2006 | 09:27 PM
GetaZforgetGT's Avatar
I just had my short block built but the standard ARP studs were installed so I needed to switch the six main studs out for the Milodon studs that would except their windage tray.
Need you guys to check my procedure and see if I did it right.
1. Cleaned all the new studs with break cleaner or lacquer thinner.
2. Removed 1 original main stud from 1 cap. (Replacing one stud at a time)
3. Dipped block side of the new stud in 30w oil...only up to the top of the treads.
4. Install stud finger tight in block.
5. Wipe 30w oil all the way around the top threads for the nut.
6. Torque the nut to 65 ft/lb per the Milodon instructions.
Perform 5 more times.
Old Apr 2, 2006 | 05:03 PM
Re: Milodon windage tray studs installed....question
Up for the evening crowd.
Old Apr 3, 2006 | 01:26 PM
Lets see if the Monday crowd has an opinion.
Old Apr 3, 2006 | 02:28 PM
Z28SORR's Avatar
That's how I did mine.
Old Apr 3, 2006 | 02:35 PM
BlkLT1Z28's Avatar
I just used my arp studs and "modyfied" my windage tray.
But that seems to be the way to do it, that way or to use the arp moly lube
Old Apr 3, 2006 | 03:02 PM
Thanks guys...I thought I had done it right but I just wanted to make sure that there weren't any known issues with the way I did it.
13qtr
Oct 28, 2016 08:11 PM
karpetcm
Sep 15, 2015 11:07 AM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
