Milodon Diamond Stripper Windager Tray part# 32250
Old Aug 21, 2007 | 02:36 PM
Mr_Bond's Avatar
This is just an FYI post
Tray installed on an 383 LT1 with 6 inch Compstar rods and 3.75 Compstar crank.
Require clearance for rods and dip stick
Old Aug 21, 2007 | 03:38 PM
Colin91Z's Avatar
Thats a nice looking piece
So are you planning to use a stock pan with this? And if so, do you have to modify the pan to fit properly? And what main cap studs did you use to mount it?
Old Aug 21, 2007 | 05:44 PM
Mr_Bond's Avatar
This is with covette block. The stud are APR 234-5601. The cap are Pro Grams for 4-bolt main block (striaght caps). No stock pan modification needed.
Old Aug 21, 2007 | 09:12 PM
89TramsAmGTA's Avatar
I have a copy of that windage tray made by Speedway. It went on my L98 buildup with a Vortec 4 bolt block. Used the Speedway bolt kit for the windage trays. I used the Milodon 6 quart oil pan that is paterned after the factory oil pan. Fit with no problems.
Old Aug 22, 2007 | 10:09 AM
awdfun's Avatar
I am running the same windage tray on my LT1 Monte. Its a 383 with 6" rods and had no clearance issues with the crank, rods, eagle splayed caps, or oilpan
Old Aug 22, 2007 | 12:05 PM
Vicious95Z28's Avatar
I've got one at home in my basement. I never used it I put the factory back in when I did the rebuild. I was having some clearance issues at the fron of the tray and the pan for some reason. I wonder why?
Old Aug 22, 2007 | 12:29 PM
Danny McAdams's Avatar
I have used several of these strippers, also pans with trap door for oil control. I add a splash shield at oil pump to keep oil off 7+8 rods and pistons. I have been satisfied with any product I used from Milodon so far. Danny Mc
Old Aug 22, 2007 | 12:36 PM
Colin91Z's Avatar
Cool, just curious I have a vette block as well
HectorM52
Jul 30, 2017 11:46 AM
realistyc
Jul 28, 2015 07:32 PM
mrwz28
Jul 8, 2015 09:11 PM
dfarr67
Apr 10, 2015 07:44 PM
