milling heads and pushrod length?
Old Oct 14, 2006 | 05:08 PM
Fbody1's Avatar
I know everyone says to get a pushrod checker and find the correct length, but I was wondering if I had the heads milled 0.18 and the block milled 0.07 for a total of 0.25 and I used a 0.39 head gasket (stock is 0.50 right) could I figure it out this way 0.25+0.11=0.36 subtract 0.36 from the stock length pushrod of 7.200 =7.164 ?
Old Oct 14, 2006 | 05:26 PM
Josh'95Z28conv's Avatar
Re: milling heads and pushrod length?
Just check it man. Its easy.
Old Oct 14, 2006 | 09:28 PM
89TramsAmGTA's Avatar
You have also changed valves and most likely a valve job. Like was said above you need to check it to be sure.
Old Oct 14, 2006 | 10:09 PM
MYT30TH's Avatar
Real world vs. Paper does not always Work..... be smart and check the geometry
Old Oct 15, 2006 | 07:31 PM
Fbody1's Avatar
thanks , I never thought about the valve job and its effect's on this, I guess I will get a checker from some where and check them.
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Roadie
Feb 16, 2015 10:34 AM
