In The Middle Of Fuel Pump Install......quick Question
Old May 1, 2004 | 03:40 PM
LT1 PWRD's Avatar
Question In The Middle Of Fuel Pump Install......quick Question
Does the strainer have to go from left to right or is it front to back?
Does it even matter?
Reason why is because I found it easier to put the sending unit in with the strainer front to back. Will that be a problem????
Old May 1, 2004 | 03:43 PM
OBE1 95Z28's Avatar
It probably doesn't matter. I mounted mine left to right as that's how the stock one came out. If your arm's thin enough to stick in the tank and guide the assembly in place you should be able to get the strainer in the right position.
Old May 1, 2004 | 03:44 PM
Red96Lt1's Avatar
I don't think it matters. I just put mine on there however I felt like it and no problems yet.
Old May 1, 2004 | 03:45 PM
LT1 PWRD's Avatar
I just don't want to put it in the wrong way and somehow the damn thing might pop off some day!
Old May 1, 2004 | 04:05 PM
OBE1 95Z28's Avatar
The strainer is flexible so it's not putting any load on the retaining surface.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
