Meziere wiring ?s
Old Jan 23, 2003 | 11:13 AM
cadrez28's Avatar
Meziere wiring ?s
Hey all,
I am looking to rig this thing up tonight and need some info. I did a search and found a couple of diagrams to use. Here are those links:
http://ken.lowrance.com/Projects/CSI...mp/Default.htm
http://www.akmcables.com/2ledmez.jpg
I am going to do the install to a switch I manually have to hit in order to turn the pump on. I will route the light indicator in the switch to the power wire on the pump between it and the relay for proof that it is running. The question is that these diagrams require a diode and I have no idea what that is or what it does. So can anyone explain please and maybe point me in the right direction as to where I get one? Hey thanks for any info in advance all.
Old Jan 23, 2003 | 01:06 PM
QUASARBLUEZ28's Avatar
I believe those are blocking diodes, which basically allows current to flow one way. Radio shack should have them.
Old Jan 23, 2003 | 01:10 PM
cadrez28's Avatar
I only need that if I run a switch and a connection from another power source right?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
