Metal Shaving Danger
Old Jun 27, 2006 | 02:09 PM
JustNO's Avatar
Today before we bolt the LT4 intake on my new 383, I sprayed air with compressor in the intakes of heads. Engine was built already, so there is no metal shaving,its all clean. But after a while I started to be worry if any metal piece that I couldn't see (very small like 0.5mm point) could be drop in combustion chamber that would be a big problem??
Old Jun 27, 2006 | 03:10 PM
JustNO's Avatar
Re: Metal Shaving Danger
13 view, no reply. maybe I couldn' explain well because of my bad spelling (sorry )
A few (less than 5) tiny metal could cause any problem? Or they go away?
Old Jun 27, 2006 | 07:45 PM
MachinistOne's Avatar
So some of the valves were open and you blew air in there to clean the ports out? Do you have a clean area that you are assembling in? Are you worried because you had metal shavings elsewhere, or just something random that floated through the air?
If you have been clean about everything it should be no big deal, something that small can pass through the chamber and not hurt anything, it may sit on a valve seat and miss a little at first, but it will burn up or get blown out.
I would be panic sticken if there was glass bead or steel shot in there, but otherwise dont worry about it.
Old Jun 28, 2006 | 01:42 PM
JustNO's Avatar
Engine is already assembled when it came to me. They sent intake and engine separately. They close the intake area of the engine with some paper. Before we bolt the intake on I blew air to clean the area from anything. A few tiny pieces flied and I couldn't see if they jump into the intake. I also couldn't see what they are. So if any metal piece (piece = smallest point you can see with your eyes, not a shot) jump in should I be worry about. That was my question.
Old Jun 28, 2006 | 07:49 PM
Bolt it together and have fun.
Old Jun 28, 2006 | 07:54 PM
Mike96z's Avatar
It'll be fine.
PCLZ28
Dec 24, 2015 05:19 PM
football4life
Oct 4, 2015 07:48 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
MattFick
Feb 15, 2015 10:16 PM
dreamer1q
Sep 12, 2002 01:00 PM
