Metal polish on rotors
Old Mar 2, 2004 | 10:38 PM
Tair's Avatar
I know this should be in the Show & Shine section, but I needed a quick response to my question. My rotors all have quite a bit of orange/brown rust on them. Is it okay to use a regular metal polish to clean the rotors, or is this going to affect the brakes? I figured it might be alright to use as long as I wash all the polish off well afterwards, so none of the polish gets on the calipers/pads. Just wanted to ask you guys before I did anything stupid!
Old Mar 2, 2004 | 10:45 PM
jbird's Avatar
if it's just surface rust where the pad squeezes I would just drive it like that. a few times of hitting the brakes and they'll be back to normal, and that way you don't have to worry about messing anything up
If I did use polish, I'd make sure to wipe all of it off and then clean them good w/some brake cleaner.
hope this helps ---J.Bird
Old Mar 2, 2004 | 10:52 PM
Red96Lt1's Avatar
Just drive it and use the brakes. If it's the back ones and it's hard to get rid of it, use the ebrake when braking.
Old Mar 2, 2004 | 11:16 PM
Compstall's Avatar
FYI, from what I've been told using the e-brake has nothing to do with the rear rotor surface and doesn't utilize the rotor pads. The e-brake uses these little pucks that press against the inner part of the rotor.
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
jayblev95
Sep 26, 2015 09:44 PM
Daluchman1974
Sep 11, 2015 06:12 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
