metal chips in oil
Old May 30, 2004 | 04:45 PM
ci.cnc.97ss's Avatar
metal chips in oil
I changed my oil today and noticed on the magnet of the drain plug there was very fine metal chips, i pored the oil out of the filter into a glass and there is metal on the bottom of the glass now. can somebody please tell me what this could be.
Thanks for your help
Old May 30, 2004 | 05:13 PM
the car has 114,000 mi. just changed over to mobil 1 last oil change.
Old May 30, 2004 | 05:48 PM
Lyle A's Avatar
It could be flakes off gears somewhere or from the valvetrain. Whatever it is it's steel. Bearings are non ferrous.
Old May 30, 2004 | 09:54 PM
So should i not worry about this?
Old May 30, 2004 | 10:03 PM
Robs97Z28's Avatar
yes, you could have a major problem on your hands. I was just giving you the easiest place to start with. More then likely you are going to have to pull the pan, so you can find what bearing has spun, timing chain, piston or even a broken piston ring.
Fatdog2
Mar 31, 2015 06:50 AM
Jonnybegood
Parts Wanted
Feb 10, 2015 07:50 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
