melting rotors on distributor help!
Old Sep 11, 2012 | 07:45 AM
  #16
96capricemgr's Avatar
Re: melting rotors on distributor help!
You could easily think it seated but have the bolts pull the opti down more and put pressure on the opti with the cam pin.
It is also very likely the cam pin could be pushed back in further without removing the timing cover if you can verify that it is too long using playdo or something.
Old Sep 11, 2012 | 04:16 PM
  #17
2QUIK6's Avatar
Originally Posted by speedygonzales
Probably not a good idea to shim it out since I believe the timing cover seal rides against the opti flange. Would probably leak.
Yes it does but the seal has plenty of surface. Not recommending to shim it more than about 1/8 inch or so, and that's if the dowl can't be pushed further in with it in the car and he doesn't want to grind it down some and risk getting metal flakes in that same seal.
Old Sep 15, 2012 | 06:25 AM
  #18
Guest47904's Avatar
Guest
According to what reputable source?
Old Sep 15, 2012 | 09:05 AM
  #19
2QUIK6's Avatar
Pin needs to contact the opti at least to half the depth of the key way..got to use a few brain cells to determine what depth is needed, not a blanket determination to just shim it to the max 1/8...think
Old Sep 15, 2012 | 09:32 AM
  #20
This thread is heading in the wrong direction. Measure the pin length and be done with it.
Old Sep 16, 2012 | 06:51 AM
  #21
badass383's Avatar
Seriously? Shim the opti out? Now I've heard everything.
Old Sep 16, 2012 | 07:53 PM
  #22
2QUIK6's Avatar
Maybe some of you experts can explain why shimming out the opti is such a horrible thing?
I had the grinding noise a long time ago coming from the opti and it was suggested to me on this board to determine how deep the dowl pin was sitting into the opti and then either see if the pin can be tapped lightly and pushed in further, or shim out the opti.....
The dowl pin in my case would not budge with a few light taps and was pushing into the back of the opti drive so I used 1/32 thick washers and shimmed it out...Worked like a charm, no more grinding noise, been well over 50k miles since and no oil leaks..
Seemed like a logical and easy solution rather than beating any harder on the cam snout or trying to grind it down and get metal flakes in the opti seal, etc..??? I've seen this suggested on several threads where folks describe a grinding sound coming from the front.
Old Sep 16, 2012 | 11:22 PM
  #23
I didn't say it was a "horrible thing". But deciding to shim the Opti before actually measuring the length of the dowel pin makes no sense at all.
My concern with the thread was that it appeared it was getting to the point of name calling and insults about to be thrown by egos, and I was simply trying to get it back on track.
Old Sep 17, 2012 | 08:56 AM
  #24
2QUIK6's Avatar
Never said to shim without measuring, only after determining the pin is bottoming out in the back of the opti, which would be a cause for the grinding noise, hence why you use the putty to see the actual impression of the pin into the opti.
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
jayblev95
Sep 26, 2015 09:44 PM
autoxr166
Sep 25, 2015 04:21 PM
tommalcolm
Sep 11, 2015 03:39 PM
