Melling oil pump question
Old Oct 12, 2011 | 08:34 AM
Dtimekw's Avatar
I have two oil pumps, HV and SV/SP (10550 and 10554). I cant find the same pickup that is currently on my HV (small tube). Since the new pump (SV/SP) is a 3/4 tube, my question is this, can I switch oil pump body covers? The two appear to be the same. This way I can still run my aftermarket small tube on the SV/SP pump. Also, I would like to up the pressure a bit, what spring do you recommend? My mains are ~.0025 and rods are ~.0029. Thanks guys.
Old Oct 12, 2011 | 02:26 PM
Dtimekw's Avatar
Re: Melling oil pump question
I talked to Melling and was told the M55's have the same cover and are interchangable. Just be sure and check which spring is in them and make sure you switch those too.
Old Oct 12, 2011 | 02:42 PM
GM white spring or Melling pink are the same 70# spring.
Old Oct 12, 2011 | 04:07 PM
Dtimekw's Avatar
Thanks Shoebox!
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
