Melling Lifters Any Good?
Old May 25, 2009 | 12:48 PM
Hal Fisher's Avatar
Well I bit the bullet and after just having done the intake gasket fix and noticing a tick I went and pulled the intake back off (that "Right Stuff" gasket goo certainly sticks!). My local parts store has Melling lifters that I could get today or I'd have to wait for LS7 lifters. Are Mellings OK or should I wait and go with the LS7 lifters?
Hal
Old May 25, 2009 | 01:07 PM
bombebomb's Avatar
Why do you say "the right stuff" sucks?
Everyone recommends ls7 lifters, they are fairly cheap also. That is all I know.
Old May 25, 2009 | 01:18 PM
Hal Fisher's Avatar
No, I said The Right Stuff was sticky. It was far harder to pull the intake off with it on (or maybe I just did a better job). I had to use my digging pole to pry the intake off (the digging pole is 4' long with a flat edge on one side, perfect for this job!). I liked how TRS mated to the surfaces on each side and felt just like rubber. I'll certainly use it again!
Oh, and the reason I am asking about the Melling lifters is because I can get those today and put it all back together but if I went LS7 I'd have to wait to get them and then check the pushrod lengths (I have 1.6 rockers on) and that would take a few days and the weather is starting to heat up.
Hal
Old May 25, 2009 | 01:23 PM
bombebomb's Avatar
Hal
/facepalm, I misread your statement. I will leave now.
P.S. I knew why you was asking hehe, I just misread the top part all wrong.
HectorM52
Jul 30, 2017 11:46 AM
alex5366
Feb 17, 2015 08:12 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
