Melling HV pump oil pressure problem
Old Jul 1, 2007 | 08:03 PM
ramair96ws6's Avatar
I had been having problems with keeping oil pressure in the higher rpms 4000+ . So i did some searching on here and everyone said it was the stock pan.
well they were right. I bought the LT1 moroso pan with the correct melling pickup tube and now my oil pressure is perfect. 80 PSI at WOT!!
So, Thanks so much for this forum!!! It saved me from pulliing a perfectly good motor just to see there was nothing wrong with it!!
Steve
ps. I had to mod the pan pretty good to get it to go on while the motor was stil in the car. a lil cutting and welding was needed.
Old Jul 2, 2007 | 01:11 AM
SS MPSTR's Avatar
yep...glad you found your issue early. some of us learned an expensive lesson with this issue. got any track times with your car?
Old Jul 2, 2007 | 08:44 PM
the best i have done tith the car here in vegas is a 11.005 @ 132
I know the car has some better times in it i just havenet went to the track that often
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
