Melling High Volume oil pump....
Old Oct 31, 2003 | 12:30 AM
S.J.S.'s Avatar
Hey I just got the Melling High Volume and was wondering if you guys who have them went with the stock spring or the one that comes in the pump (the high pressure one).???
O yeah.... does the oil pick up bolt back to the pump??
thanks guys
Old Oct 31, 2003 | 09:21 AM
Perry93TransAm's Avatar
I am using that pump in my #*# right now, at first I went with the low pressure spring that comes with it, but I had a few troubles with it first under gas the pressure stayed at 40 PSI no matter what the rpm was, at idle it dropped to 25, I later removed the pan and put the stock LT1 spring in the pump, now my pressure rises with the rpms (10 psi per 1000 rpm) and it idles around 25 psi warm. I would clean and reuse the LT1 pumps stock spring.
Old Oct 31, 2003 | 12:07 PM
S.J.S.'s Avatar
Well there is a spring that comes with the kit. I was wondering if I was gonna throw that one in.
Old Oct 31, 2003 | 12:34 PM
R_Andersen's Avatar
I'm using the same high volume pump and I'm using the spring that was in the pump when I got it. In my 383 I get 25 psi at idle and it raises up to 70 psi at 4000 rpm and stays there all the way up to 6500. I know the pump came with a second spring in the box but I think that was the regular spring which means I'm using the high pressure one.
-Rob
KYWes
Apr 15, 2015 07:11 PM
KYWes
Apr 15, 2015 05:48 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Hoodshaker
Aug 27, 2002 02:32 PM
