melling 10554 high pressure?
ok so i just ordered this melling 10554 oil pump
http://www.summitracing.com/parts/MEL-10554/
iv been searching and i have been reading alot about the 10554 and using a high pressure spring...
is this the right spring to order
http://www.summitracing.com/parts/NAL-3848911/
and is this the right pickup?
http://www.summitracing.com/parts/MEL-155S/
what will my oil pressure be at around idle and like 2-3k normal driving??
also how do i change the spring?
Oil pressure is a product of the pump plus bearing clearances. No one can tell you what your pressure will exactly be.
The spring is easily changed (if needed) by removing the bottom plate, knocking out the rolled pin, swapping spring, reinserting rolled pin and reinstalling the plate.
If that Melling pickup is exactly like the GM 12550042 , then it is the right one. I have not seen them side by side. Hard to tell by pictures, but it looks pretty close. It is definitely the right diameter for the pump.
http://shbox.com/1/oil_pump.jpg
does anyone know where we can find a color chart to reference the color vs the spring pressure?
i found this but it doesnt help much
http://www.melling.com/Portals/0/SPR...20announce.pdf
heres a link to the 10554 page on mellings website...they say its machined with the pink spring installed for higher pressure??? also says they include a yellow spring for low pressure?? can anyone shed light on this?
http://www.mellingselectperformance....nOilPumps.aspx
So how's that build going? Getting it done before you deploy?
Use the white or the pink spring. Same difference.
If you have the pink spring already, you are good to go. Again, the Melling pink and the GM white are both rated at 70#.
