me and this dam trans are gonna fight!
Old May 16, 2003 | 09:16 PM
chevyboy_z28's Avatar
ok first off all the other day i broke my 2nd trans mount (a 1le mount at that) and i am kinda stuck on where to turn to now. at first i was thinking of getting another one but then i figured it would only be a couple months before i broke this one so i have decided to go with a poly one. second of all my freakin trans is tryin 2 play games on me. my trans has started makin this vibrating sound when i start going from a dead stop and sometimes in each gear. it also does this when i stall it up to about 2000rpms. ive been taking it easy since i started hearing this noise, im gonna take it back to the shop that rebuit it as soon as we get out of school for the summer (warranty), but does anyone know what this is.
Old May 16, 2003 | 10:06 PM
94Z & 96SS's Avatar
After I put my poly bushing on I have more vibration. Don't know if the vibration is causing your noise but it's something to look at.
Old May 17, 2003 | 09:34 AM
naw, the vibration is what i think im hearing, i dont feel any vibration, it justs sounds like there is metal vibrating somewhere right under the center console (im thinking its somethin inside the tranny)
Old May 17, 2003 | 11:35 AM
anybody, im about to go pick up a poly trans mount hopefully it will last, but does this vibration thing sound familiar to anyone?
Old May 17, 2003 | 12:47 PM
chitnblr's Avatar
had a poly transmount installed and did feel a vibration i didnt previously feel, but got used to each in a few days
Old May 17, 2003 | 01:52 PM
Jake77444's Avatar
Hey I get that same noise, and have many problems with my transmission. My mechanic said he heard it too and it sounded like a water pump bearing but I know it is not. If you figure out what this is let me know because im going to be going on my 3rd transmission rebuild in the last year.
Old May 17, 2003 | 04:32 PM
any transmission experts on here?
Old May 17, 2003 | 05:19 PM
graham's Avatar
The reason why the factory mount is rubber is because the rubber disipates road noise real well. When you go to the poly, your gonna hear more 'mechanical' or 'road' noise b/c the poly (although way stronger) doesnt disipate the sounds/vibrations.
But....although you'll notice more 'noise' I dont think you'll have considerable 'vibration' with just a poly trans mount. Its just like having poly LCA mounts, they transfer a little rear end sound that the rubber would absorb. For example, my gears are quite tight and the slight whine got real loud after a Sphon PH rod and Lakewood LCA's.
If your trans mount is broken (like completely in 2) it might be the front U-Joint is out of line (IE: the tailshaft is kicked a little to one side and maybe sitting lower than its supposed to. Also, under torque, but not necessarily hard driving, the rear of the trans can and will move around, throwing your drivetrain out of line.)
You could have also damaged the front U-Joint by driving with a broken trans mount.
Good Luck!
Old May 17, 2003 | 09:59 PM
is this the noise im hearing?, im not worried about the mount (not to sound arrogant) i wanna know what it is im hearing cause it hasnt always made this noise!
Old May 17, 2003 | 10:08 PM
LJ93Z28GM's Avatar
If it sounds like you are throwing around a aluminum can under your car. You might have somehow gotten something inside of your trans inspection cover (cover that hides the convertor)
I have seen a few cars where the rear main bolts back out and fall down there, a convertor mounting bolt, another person dropped a piece of metal while working on his car with his starter removed and where did it fall but in the notch for the starter.
If they stay in there long enough it will crack the housing.
It is a shot in the dark if you wanna take a look in yours.
Old May 18, 2003 | 06:20 PM
i put a poly mount on today and i havent heard this noise anymore so im not gonna worry about it right now...maybe it wasnt that big of a deal?
NewsBot
May 16, 2015 05:20 PM
CARiD
May 6, 2015 07:49 AM
CARiD
Feb 9, 2015 09:35 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jul 4, 2005 05:00 PM
