McLeod clutch help !
Old May 22, 2003 | 05:41 PM
1995 Z-28 6 speed's Avatar
Question McLeod clutch help !
Hello guys, I've installed my McLeod double clutch and now I'm having some problems... All the gears hooks very well, except for the reverse that I can't put it... And the car starts to go only at the middle of the course of the clutch pedal... What I have to do to correct this problems ? Help me !
Thank you !!!
Old May 22, 2003 | 05:44 PM
InjectedSS's Avatar
sounds like the clutch isnt releasing all the way! how many miles is on your car? might be time to upgrade your master and slave cylinder!
Old May 22, 2003 | 07:09 PM
Fastbird93's Avatar
You should have had a new master cylinder that comes with the clutch. If you didn't install that, do so, and adjust where the clutch engagement point is.
Old May 22, 2003 | 10:12 PM
I've installed the new master cilinder when I bought the clutch new (about 15000 miles ago), but now I only replace the discs... I have to upgrade the master cilinder ? What's a goos one ? Where I can buy it ?
Thank you for your help !
Old May 23, 2003 | 12:00 AM
Come on guys... help me...
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
