Maximum valve lift on 350 LT1
Old Mar 28, 2003 | 01:12 PM
Stealth Z's Avatar
Anyone know what the maximum valve lift is before you hafta worry about hitting the pistons? My motor isn't together yet for me to check, and I was just curious if anyone knew. . .
Old Mar 28, 2003 | 01:18 PM
Stealth Z's Avatar
LT4 heads 2.00 valves stock pistons, etc. . .
If theres a formula for this how do i go about finding it or can you tell me?
Old Mar 28, 2003 | 02:33 PM
Type_O_Negative_1320's Avatar
Hey Rob, remember that you have to take these into account:
cam lift
possibly the lifters...don't know if they come in different heights
pushrod length
rocker arm ratio
length of valve stem
size of valves
whether or not the pistons have relief cuts in them...how deep they are cut and the shape of the relief...etc
head gaskets
Any variation of the above from stock will change the piston/valve clearance. I want to say that I remember hearing the maximum you could go would be around 0.650", but don't quote me on that.
On another note...is that thing coming off of the jackstands any time soon?
Old Mar 28, 2003 | 03:20 PM
jetman's Avatar
Thumbs up
I e-mailed Craig at GTP racing, they built a LT1 with the bottom end remaining stock and the cam they installed was 235/242, 568/592, 112 with no clearence issues on factory pistons. Hope this helps.
Old Mar 28, 2003 | 05:18 PM
Beast96Z's Avatar
With the use of mostly stock parts, you can usaully be safe not going over .600 lift.
Old Mar 28, 2003 | 09:51 PM
Stealth Z's Avatar
cam lift
pushrod length
rocker arm ratio
head gaskets
none of that matters. . . except for
size of valves
valves opening .600" is a valve opening .600" no more no less. . .
Is that final lift after 1.5 or 1.6?
Old Mar 28, 2003 | 09:54 PM
Ai's Avatar
Ai
3.48" minimum on a stock shortblock
Piston to valve is a function of lift vs. duration. Most guys dont check with common combinations... cc306's, gm847's etc.
IMO, always check, it doesnt take long to do things right, but it'll take forever the time you do it wrong
Old Mar 29, 2003 | 03:36 PM
You're right, Rob...I thought about it some more after I posted that and then realized that I'm a retard. My brain doesn't work too well on Fridays.
Old Mar 29, 2003 | 07:33 PM
Stealth Z's Avatar
wasn't trying to make you feel retarded jeff
LeftoverChinese
Jan 14, 2024 03:03 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
centric
Aug 15, 2002 09:04 PM
