Brake Break in Procedure
Old Mar 29, 2003 | 06:50 PM
TobyZ28's Avatar
Arrow Brake Break in Procedure
I just got new fronts (calipers and pads) put in. Does anyone know a good break in procedure to significantly increase the pad life? I did a search and found some threads mentioning it, but didn't come across any instructions on what to do Hope someone's able to fill me in here
Old Mar 29, 2003 | 07:09 PM
http://www.baer.com/Support/TechTips.aspx
Old Mar 29, 2003 | 07:28 PM
OldSStroker's Avatar
Baer's procedure is good for HP pads.
Another, somewhat simpler procedure is 20-30 1/2 g (medium braking) stops from 45-55 mph, like in suburban traffic. Allow a few minutes between stops, and you don't have to do it in the first few miles.
You are trying to get the pads and rotors intimately acquainted.
Sometimes a gradual approch makes a relationship last longer.
After that, try a hard stop from 65 or so. If you get into ABS cycling on dry pavement at 65, it's probably a little too hard. Of course, if you've never done that, you really should consider trying it under controlled conditions before you have to do it "in anger".
Old Mar 29, 2003 | 07:35 PM
xxsaint69x's Avatar
get the car up to 100+mph then slam on brakes.
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
Boss002
Jul 24, 2015 10:47 AM
whitehooptie
Jul 12, 2015 06:10 PM
