Maximum Lift
Old Apr 23, 2006 | 10:14 AM
1LESSZ28's Avatar
Maximum Lift
What is the maximum valve lift that the stock 1.5 rockers can support?
I will be upgrading the springs/locks/retainers.
Thinking about xe high lift with accelerated ramp rates.
Old Apr 23, 2006 | 01:44 PM
Stoopalini's Avatar
Re: Maximum Lift
Rockers do not have a min lift spec that I know of.
the springs are what you need to worry about in terms of lift limits.
Thomas.
Old Apr 23, 2006 | 03:24 PM
jsetzer's Avatar
Re: Maximum Lift
I would not run much bigger than the hotcam.
The cc306 destroyed my stock rockers with its tiny lift. Some people have gotten away with it, but after just a few redline pulls I snapped 1 and the rest were shot.
Old Apr 23, 2006 | 04:16 PM
Stoopalini's Avatar
Re: Maximum Lift
What RPMs were you pulling when it broke?
Thomas.
Old Apr 23, 2006 | 05:14 PM
93LT1355's Avatar
Re: Maximum Lift
why go to the trouble of changing the springs and everything for the cam and not put some new rockers on it.
Old Apr 24, 2006 | 12:21 AM
jsetzer's Avatar
Re: Maximum Lift
Thomas.
6400-6500 ish
Old Apr 24, 2006 | 01:58 AM
sprayedtransam's Avatar
Re: Maximum Lift
a little more than .500 lift and you are going to be heading for trouble with the stockers
Old Apr 24, 2006 | 04:27 AM
rskrause's Avatar
Moderator
Re: Maximum Lift
If you are replacing the cam with a higher lift cam that requires more spring, replace the rockers. You can alwys use a roller tipped stamped rocker designed for high lift if money is real tight. Like the Magnum rockers from Comp http://www.compcams.com/technical/Ca...106-07/268.pdf. Don't forget to use guideplates with these. They run $150-175 or so.
Rich
Old Apr 24, 2006 | 07:42 PM
TransAmGT94's Avatar
Re: Maximum Lift
Cheaping out on rockers has put me where i am now. I put a rocker that had a max lift of .550 on a .610 lift cam. When i did it i didnt think about there being a lift max but to make a long story short i cracked a cyl put a whole in 2 pistons beat the hell out of the other 6 bent a rod and put a whole in one head while only banging up the other
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Aug 17, 2015 09:50 AM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
