Max lift on Crane Springs?
Old Apr 13, 2007 | 01:13 PM
69gto96z's Avatar
Does anyone know what the max lift these springs can take is?
http://store.summitracing.com/partde...&view=1&N=700+
Old Apr 13, 2007 | 03:04 PM
Pyrodawg's Avatar
http://cranecams.com/index.php?show=...&lvl=3&prt=123
those are the springs i have on and thats the link to the specs of them
Old Apr 13, 2007 | 03:07 PM
jsetzer's Avatar
Depends on the setup, you could run them crazy high if you are crazy. (???)
Anyways what are you thinking? I ran them on the 847, shimmed them because I was floating valves, then crushed a roller on a lifter, not collapsed but actually grenaded the roller tip.
Old Apr 13, 2007 | 03:32 PM
69gto96z's Avatar
I plan on running them on a comp 306
Old Apr 13, 2007 | 03:39 PM
seawolf06's Avatar
Looks like .700", but I'm not as familiar with dual springs.
Did you have stock heads and had to shim for the GM847? I'm surprised, but the locators might be really thin. What was your final install height?
Old Apr 13, 2007 | 05:59 PM
jsetzer's Avatar
I honestly think it was just a bad lifter, but at min go with new stockers.
I think (been a while) that they were installed @ 1.76 and 1.74
Old Apr 13, 2007 | 07:57 PM
truedualws6's Avatar
99893 Springs
Unless you have longer valves and plan on installing those at 1.80" or 1.85"
you will be running too much closed pressure. Assuming that you use a .040"
to .060" shim/locator, the closed pressure will be in the 157-169 lb range with
stock valves. This us just my $.02. You usually can't go wrong with the springs
specified on the cam card.
HarleyZ28
Oct 5, 2015 06:23 AM
detroit1994z28
May 14, 2015 12:09 AM
nikolt1
Feb 27, 2015 09:10 PM
Don 97 SS
Jul 11, 2005 08:50 AM
