max bore
Old Oct 18, 2006 | 01:01 PM
crazydavez28's Avatar
max bore
can an lt1 engine block be bored out to 4.125" w/o the cylinder walls being too thin?
Old Oct 18, 2006 | 01:11 PM
seawolf06's Avatar
Re: max bore
Pretty sure you'd have to get a SBC for that!
Old Oct 18, 2006 | 01:17 PM
FuryZ28's Avatar
Re: max bore
Yeah, Victory Race Engines told me that .040" was the maximum safe bore for an LT1...
Old Oct 18, 2006 | 02:03 PM
seawolf06's Avatar
Re: max bore
Some can do .060 for the 396, but that's about the limit.
Old Oct 18, 2006 | 02:05 PM
Javier97Z28's Avatar
Moderator
Re: max bore
Doesn't take .060 to make a 396.. I don't recall if it's also .030 or if it's .040.
.060 from what I understand, the block will need to be sonic checked.
Old Oct 18, 2006 | 02:31 PM
Ray@NitroDaves's Avatar
Re: max bore
383 = 4.030 bore 3.75 stroke
385 = 4.040 bore 3.75 stroke
396 = 4.030 bore 3.875 stroke
398 = 4.040 bore 3.875 stroke
Old Oct 18, 2006 | 02:47 PM
VK's Avatar
VK
Re: max bore
Yes .060 over have the block sonic checked... some blocks won't do .060 over on the street for long if they don't pass the sonic check... worth the peace of mind IMO!
Old Oct 19, 2006 | 12:30 AM
Re: max bore
is there any kind of sleeve that could make it possible? is it even logistically possible? or would the cost of that just be ridiculous?
Old Oct 19, 2006 | 01:43 AM
seawolf06's Avatar
Re: max bore
I assume you're doing this to get max power. For all the money you're going to spend on this LT1 engine to get that many cubes, you should just go to a regular SBC and bore that out to the max. You'll get much more power for your money.
Old Oct 19, 2006 | 11:53 AM
Re: max bore
You can sleeve the LT1. There's been a couple discussions on this, one of them in the past month or tow. A "search" should turn it up. One of the people who used to post here more regularly built an LT1 "427" using sleeves.
Old Feb 22, 2007 | 12:26 PM
Mike96z's Avatar
Dont forget 388ci 4.060 - 3.75 stroke lol
Old Feb 22, 2007 | 08:59 PM
it's not really about being pratical but more about being able to say 427.
do vortec heads have the same angle as lt1?
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
Z Power
Sep 19, 2015 11:19 PM
heus
Sep 8, 2015 12:01 PM
