Mas
Old Mar 14, 2004 | 02:19 PM
1984camaroz28's Avatar
Mas
is it worth porting it after descreening it.
Old Mar 14, 2004 | 02:58 PM
97Z-M6's Avatar
i assume your talking about the MAF dont even mess with it. if want to descreen it thats ok. but dont port it.
Old Mar 14, 2004 | 03:00 PM
Kryckter's Avatar
NO, do not port that out. It will do more harm than good. Alot of people say it will mess up the fuel maps and make the car run worse. Do a search and you can find out alot of stuff!
Old Mar 14, 2004 | 03:36 PM
snksknr94's Avatar
If your car is basically stock it MAY be beneficial, as the cars come from the factory on the rich side and a ported MAF sensor will help lean it out. If you start modding I'd leave it alone, I wouldn't even descreen it. I had a ported one on my car and it leaned it out to much after the cam and headers so I went back to a stock one with the screen and all. The screen actually acts as an air straightner to improve airflow. Get you car on a dyno with a wideband setup and see what it looks like, then use a program like LT1edit to lean it out. Playing with the MAF housing lead to too many variables.
Old Mar 14, 2004 | 04:02 PM
is it worth buying an aftermarket one
Old Mar 14, 2004 | 04:07 PM
97Z-M6's Avatar
nope just use the stock one.
when you get over 500hp then worry about.
Old Mar 14, 2004 | 04:12 PM
ok thanks
takedown171lb
Jan 4, 2004 12:50 PM
DavidNC
Aug 22, 2003 01:59 PM
lordmetalz28
3rd Gen / L98 Engine Tech
Jun 18, 2003 07:32 PM
