Mas
If your car is basically stock it MAY be beneficial, as the cars come from the factory on the rich side and a ported MAF sensor will help lean it out. If you start modding I'd leave it alone, I wouldn't even descreen it. I had a ported one on my car and it leaned it out to much after the cam and headers so I went back to a stock one with the screen and all. The screen actually acts as an air straightner to improve airflow. Get you car on a dyno with a wideband setup and see what it looks like, then use a program like LT1edit to lean it out. Playing with the MAF housing lead to too many variables.
takedown171lb
Jan 4, 2004 12:50 PM
