march pulleys
Old Jun 1, 2005 | 12:17 PM
Brian Sutherland's Avatar
march pulleys
I went to install my two piece march power pulleys on my 94 Z the alternator pulley doesnt fit. Is this a press fit??
Brian
Old Jun 1, 2005 | 12:34 PM
BUBBA's Avatar
Re: march pulleys
I installed mine on my 97SS and it wasn't a press fit. Did require an impact wrench to get the nut off and back on, since the pulley would turn whenever I tried to undo the nut.
I can't remember, but isn't there a key holding the pulley in place? So when you say it doesn't fit, you may have to line it up very carefully and gently tap in on with a piece of wood and mallet. But then again, if the pulley is smaller than the shaft, it is obviously not going to fit no matter what.
My guess is, you just need to give it a bit of help.JMHO
Old Jun 1, 2005 | 12:39 PM
n2oblkz
Guest
Posts: n/a
Re: march pulleys
I have the same pullies and mine went right on with an impact gun.
Old Jun 2, 2005 | 12:18 PM
Re: march pulleys
well i got the stock pulley off no problem I just cant get the new pulley to slide on far enough to start the threads. I will try pulling off the alternator and heping it on
Brian
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
Compstall
Sep 9, 2002 02:16 PM
