map sensor part #
Just curious... are you doing this because you read the thread about the "cure all" for bad gas mileage and performance by replacing the MAP sensor.... even if there is nothing wrong with it?
What is a "high performance MAP sensor"? I need to know this too.
A p/n was posted in that thread.
No need for a "high performance" sensor (never heard of such a thing), since all it does is read the engine vacuum. Any thing you want to do high performance-wise with the readings would be done with pcm programming.
