MAP problem?
Old Apr 26, 2003 | 03:47 PM
MyTMous's Avatar
MAP problem?
OK I noticed during my latest datamaster run, that on load with rpms going up and speed going up, and a steady throttle postion.
My MAP reading was going up then dropped from like 75 to 48 and stayed there, this is also the exact time my stumble I've been trying to fix happens. What could be causing me to loss Pressure in the Manifold on load, a missfire wouldn't cause this would it? But if I have a leak that happenes and more air is getting in unmeasred then that could cause too much air,.......
Anyone got an idea???
Old Apr 27, 2003 | 09:55 AM
MyTMous's Avatar
TTT
Old Apr 27, 2003 | 12:46 PM
Lions3's Avatar
Easiest way to check for an air leak, is to start the car with the hood up, walk around front and put your ear right up close to the intake plumbing. Listen for any really loud, very obvious whistling or leaking sounds.
Old Apr 27, 2003 | 12:53 PM
turbo_Z's Avatar
the MAP reading should be very close to true barometric reading at WOT. so check WOT and see if the MAP fluctuates any and that should give you a good idea if its functioning properly.
Old Apr 27, 2003 | 08:12 PM
MyTMous's Avatar
That's part of the problem I can't go to WOT without the car Crapping out, anything above 3000rpms and it's not good.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
99TransAmWS6
Mar 22, 2015 11:00 PM
Fatdog2
Feb 13, 2015 08:19 PM
Amshnock
14
Jan 18, 2015 11:47 AM
