Manually Turning Engine
I am starting my cam / RR install this weekend and had one more question (I hope only one). To install my springs, I am planning on using the method of turning the engine to TDC so the valves dont fall in when I swap springs. What is the best way to do this??? You need a special tool / socket to fit to the crank to spin it, correct? Where would I get this (or any other tool I may need), because I cannot find it anywhere. Thanks!
Re: Manually Turning Engine
Yeah, I know that is a method, but I do not have the leakdown tester or air compressor. Also, I like the idea of not having to pull my plugs and having the physical barrier of the cylinder to hold the valve rather than air pressure. Just a little piece of mind.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jul 4, 2005 05:00 PM
formula79
26
Aug 5, 2002 12:21 PM
