manual fan switch??
manual fan switch??
I want to know how to wire my fans to come on and run all the time. The car is a 95 firebirf LT1. I don't want any led lights and really don't care about any ses lights. I'm going to the track very soon and need to do this quick. I just want to be able to turn my fans on manually when I want. Thanks
heres the link http://www.xious.com/camaro/install-fanswitch.html
You will be able to turn on both high and low speeds.
Originally posted by jeremyferguson
following the diagram on the link above....does it create a problem if the pcm turns the fans on, and you have the switch turned on too?.......also, does that operate both fans?
The switch will override the pcm, but with the switch off, normal fan operation will occur. 1995-1997 3 relay fan systems operate both fans in tandem. The diagram lets you control both high and low speed operation (fans operate together).
Shoebox....you 'da man!! Thanks. One more question. The 12V that I'm tapping into.....what are the amperage requirements? Is that power actually running the fans when the switch is on, or is that just powering relays? I don't mean to be redundant, I just don't want to fry any wiring.
Originally posted by john97z28
Is there a way to wire up the fans so they can be turned on without the key on, using a relay?
I tried this yesterday with all the LED's, resistors, and diodes and my fans aren't coming on. I know I have a good ground because the LED's are working. Anyone know what might be the problem? I tapped into the H and J wires light the diagram states.
Use a meter and see if a ground is getting to where you tapped into the wires when the switch is thrown. The LEDs can work and there still be an open toward the H and J connection.
Tons of people use it just like the wiring diagram shows, so it definitely does work. Also be sure there is not something simple as a fan fuse blown.
