manley valves .100 longer... where can i buy them.
i need the manley valves .100 longer. can someone please tell me where i can buty them.
i saw racenet has them but it doesnt say if the are .100 longer.
i hate to TTT this but heads are at the machine shop and they cant cut the valves in unless i have the valves in hand. and i need to get these to loyd asap to get them ported.
please help.
is my only hope farera valves, if some has some other sugestion on good valves please let me know and also where to buy them. i found the manleys at www.racenet.net for about 80 bucks a set.
thanks
please help.
thanks
Call Combination Motorsport (702-798-8504) and get their REV valves. They are 4.960 and will work fine.
Their part #'s are SI 2.00 and SI 1.57. They are about $160 a set. If you need them quick, I am sure they can "NEXT DAY AIR" them for ya for not much more.
NightTrain66
NightTrain66
2.02 and 1.60 do not help or increase flow. from what i read and been told by porters it doesnot hurt any either but you do have to do some unshrouding.
and i would rather use a smaller valve if a larger one wont help so i can save weight.
Was looking at valves in my Summit catalogue the other day and noticed they have the ones that are .100 longer. Can you explain why you would go with a longer valve. I've got my heads off the car now and am getting ready to increase the valves to 2.02/1.60, could I benefit more with a longer valve? Are there any disadvantages?
Alot depends on what cam (lift) you are running and what springs you are using and what set up ht. you will need to make it all work. The stock length valves are fine until about .570-.580 lift. After this, a longer valve will give you more set up ht. to work with. Most springs that work with thse size cams will need a lil taller valve so the seat pressure is not too high and they are not close to coil bind.
Others might answer a lil differently but this is what I see.
If you change the length of the valve, change cams, mill heads, etc, the push rod length and rocker geometry MUST be re checked since it will USUALLY be wrong assuming that it was correct before.
NightTrain66@msn.com
hmmm...so would you recommend going with the longer valves for someone that has the following.
Cam - 847
Rockers - GM1.6RR, from HotCam kit
Springs - CMS 612
Heads - have been ported,polished, & milled yet I do not have specs right now on how much has been taken off.
Cam - 847
Springs - CMS 612
Like some of these guys mentioned.. you probably dont need a .100 long valve. Ferrea "LTx" stuff is 4.960, vs. 4.910 for the manley stuff I've had. Either one should work with most normal .550-.600" lift lobes, an lt1 head, and a decent spring (I dont know where that 612 binds etc. though). Worst case you can run a +.050" keeper and likely not have any problem with it.
Thats been my experience with the stuff anyhow
Manley doesnt make a 2.02 valve .100 longer, you have to get one custom made by Manley and the cost is pretty high. I got my 2.02/1.60 .100 longer valves from Ferrea, they were well under $200. Milodon also makes .100 longer 2.02s.
To answer the original ?, try these guys: http://www.sdpc2000.com
Originally posted by arnie
Hmmm, I'll (or someone) needs to call Manley and let them know, cuz I'm confident they don't know that yet.
Wish the Manley rep. would have told me that....
P.S. I myself, grew up, and spent a couple of decades on my family's farm. So, respectfully, it really wasn't a low blow.
Victor Lamb
Aug 26, 2017 02:52 PM
yes they do pro flow 2.02 .100 longer $148.00 top of the line except for titainum
