manifolds still glowing where to go next
Old Nov 21, 2006 | 04:53 AM
96 blz28's Avatar
ok i had a problem last week where i picked up a miss and my exhaust manifolds where glowing. It was the plug wires on the back two cylinders where not on all the way because of the metal heat sheilds. so i inspected the wires and put them back on and now it runs fine but in normal driving down the express way at 75 for 10 miles or so the manifolds still start glowing by the back four cylinders. Now i only have 300miles on the car sence i put a motor with 63k miles on it and i have not noticed this before and i drove around for a night with the hood of when i first finished the car so im sure i would of noticed that night. any ideas on where to go next. Also with having put a diffrent motor in that i believe has a cam would i have to have the car electronically tuned or dino tuned
Old Nov 21, 2006 | 07:01 AM
SS RRR's Avatar
headers or actual stock manifolds? at least at night you'll see header primaries glow, but it also can be an indication of running lean. best thing is to scan the pcm and see what's happening.
Old Nov 21, 2006 | 12:48 PM
2000GTP's Avatar
It could be possible that you fouled the plugs as well, did you check the condition of those? Also, if your car has a different motor with a different cam, depending on the specs of the cam, it may very well need some tuning.
Old Nov 21, 2006 | 01:20 PM
TobyZ28's Avatar
Please put your mods/car/year in sig so we can help you better
Old Nov 21, 2006 | 02:28 PM
94 NO TOP Z's Avatar
Check for vacuum leaks or throttle body elbow leaks (any air that is getting in downstream of the MAF).
Old Nov 21, 2006 | 03:28 PM
96 blz28's Avatar
these are stock manifolds i really have no mods that i know of the car is a 96 i bought it blown up and bought a motor off ebay and they didn't say there were any mods but it really acts like it has a cam in it. thanks for the ideas and any more will help
Old Nov 21, 2006 | 03:46 PM
TobyZ28's Avatar
Okay, how was the car running so that you think it has a cam? Does it choke when your floor it? If you have a clogged CAT the stock manifolds will glow and the car will run like complete crap (i had that happen).
Old Nov 21, 2006 | 04:11 PM
CASPER97TA's Avatar
X2 on the clogged cat. that would be the first thing i would check. un hook the cat and then run the motor and see if they glow.
Old Nov 21, 2006 | 04:47 PM
TobyZ28's Avatar
not so easy on a stock car where the cat is welded to the Y
Signs of a bad cat:
Glowing Manifolds
Glowing Cat
metallic clunkity sounds when idling coming from the Cat
Total Loss of power at higher RPMs,
Loss of power in general
Chunks of honeycomb flyign out your exhaust
Old Nov 21, 2006 | 09:27 PM
merim123's Avatar
I agree, check the cat's, I had that happen to me before too. whether they are bolted on or not, they are probably clogged.
GREEN3112
Feb 10, 2019 09:19 PM
HibachiZ28
Nov 6, 2015 12:53 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Zrout
Parts Wanted
Sep 1, 2015 06:32 PM
ShiftyCapone
Aug 27, 2015 10:14 AM
