manifold exhaust?
Old Sep 26, 2005 | 02:15 PM
BaDBiRD408's Avatar
manifold exhaust?
How long would it take to take out a passenger side exhaust manifold and what are the things you have to take out? i need some tips and how many volts just to estimate?
Old Sep 26, 2005 | 02:52 PM
2000GTP's Avatar
Re: manifold exhaust?
I'm sure the level of difficulty will have something to do with the amount of rust that has accumulated. In that case, I would get a good rust penetrant and spray down whatever you are going to have to take off. The manifold is held in by 6 *bolts*, not quite sure where the "volts" comes into play, and the manifold to y-pipe connection is another three bolts. You will need some extensions and maybe swivels for the y-pipe connection bolts and removal of the starter and alternator will help with bolt access to the manifold. Definitely spray down the bolts though, they are very easy to snap off into the head.
Old Sep 26, 2005 | 03:22 PM
BaDBiRD408's Avatar
cool thanxs a lot...How's a WD-40 that should get rid of the rust right?
Old Sep 26, 2005 | 03:33 PM
2000GTP's Avatar
Yeah, WD-40 will work fine.
Old Sep 26, 2005 | 03:40 PM
anaik's Avatar
PB Blaster is a better choice.
http://www.pbblaster.com/store/
Old Sep 26, 2005 | 04:13 PM
Z95m6's Avatar
Also be prepared to replace all the manifold studs where the ypipe connects because they are going to bust off.
Old Sep 26, 2005 | 05:11 PM
2000GTP's Avatar
That is definitely a great spot for bolts to break. I however, got lucky and I didn't break a single bolt anywhere during my header install, but then again, I sprayed every bolt three times a day for a solid week with PB Blaster and GM Rust Penetrant. End result, no broken bolts and a total of 2 Cans of PB Blaster and 1 can of GM Rust Penetrant being used.
Old Sep 27, 2005 | 01:28 PM
BaDBiRD408's Avatar
i guess it all depends on how you work on your car,if your sweet and tender with your car or your hott and wild just don't reaaly give a danmm just wanna get that shiet done>>!
Old Sep 27, 2005 | 02:40 PM
2000GTP's Avatar
Sweet and tender will save you some money in broken parts.
Old Sep 28, 2005 | 01:29 AM
revtime's Avatar
I sprayed mine down with PB blaster for 2 days and I had zero problems with my LT header install. I highly reccomend as well that you spray them down alot a few days before you start spinning wrenches.
Old Sep 29, 2005 | 10:24 AM
gibbylt1's Avatar
Definitely hose the bolts down with PB Blaster. I let the bolts sit overnight, then I used a ratchet with a 3' pipe on the end to break the bolts loose. Careful with this though, it's easier to break the bolts off since you don't have a good feel for the amount of torque you're applying to the wrench.
69z-28
Jan 29, 2016 10:46 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
spearous
Jan 12, 2015 11:03 AM
