Manifold bolt/nut?
Manifold bolt/nut?
I'm putting my lt's in this weekend, and i am noticing that on both manifolds they start out with two bolts on each side. Then the third one is a nut on a bolt that look like it goes into the head. So all you see is the threads with a bolt on it. Does this sound right if so when i put my lt's in do i take that out to put a bolt in it?? It's confusing the heck out of me. So if you have any advice ill take it b/c im stumped and dont want to go into this project not having a clue what im doing thanks
Usually, dont take LT install advice from me, but i know this for fact. the bolt/nut you are refering to is a stud with a nut half way down it. just get a deep 9/16 and take it off like a normal bolt. the nut wont come off the stud. there should be new bolts that came with your headers so you dont need the old ones.
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
